Results 1 to 2 of 2
Thread: rear radius arm zinc plated or not?
    I have an originality question: from what model onwards are the rear radius arms and torsion bar bearing box yellow zinc plated. I am quite sure that the SWB's are all black. Car in question here is a 2.2S
    Michael
    Michael Moenstermann
    Osnabrueck - Germany
    Early 911S member #1052
    'While accelerating the tears of emotion have to flow off horizontally to the ears.'
    'Understeer is when you see the tree you are hitting, if you only hear the tree then it was oversteer'.
    'You can't treat a car like a human being - a car needs love'. (all Walter Röhrl)
    Sep 2009
    UK
    A 2.2 should be Black. As should the torsion bar cover plate. Info from the 700 mile S.
    Dave
