Results 1 to 2 of 2
Thread: WTB: Brake Reservoir Plastic Feed Pipes
    I'm looking for a good used set of the 2 brake reservoir plastic feed pipes going to the master cylinder.
    All dual line 911/912 systems from 69-77 should be the same; these are the white nylon pipes with the metal ends.
    I'll take the reservoir as well but the set must be intact and undamaged.
    Let me know what you have, thanks.
