Thread: Source for Motorola Alternator Brushes
    Does anyone have a source for replacement brushes for a Motorola alternator from a 1969 T?
    The specs are in the FWM for brush size I believe- why not buy a voltage regulator with integral brushes (like a bosch) and see if the brushes fit?
    Alternator brushes are generally available on the loose- check ebay.
    Apr 2013
    Clayton, NC
    If you know the size, then this company has a good selection.
    http://iat-usa.com/catalog/
    Thanks guys for the suggestions. The brushes are soldered into the module and I didn't want to mess with that. I did find a replacement part number: 901.603.907.00 The Porsche made part is $63. I went with a part sold by Sierra Madre for $23. The module is an exact, drop in fit. The module is mostly hard plastic and doesn't require the insulator back plate. It came with new screws and washers. We'll see how it performs.
