Results 1 to 8 of 8
Thread: Euro indicator assemblies
    I have a pair of what are believed to be 73 Euro front indicator assemblies for sale.
    Both in great shape I cleaned one up a bit more than the other to show no corrosion at all, both will clean up perfectly.
    No wiring looms or rear plastic covers just what you see in the pic
    $695USD ONO for the pair, free shipping via Fed Ex.
    clyde@the-boyers.biz
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Dec 2011
    Palm Coast, FL.
    Those are the Euro TS housings Clyde
    ESR # 2300
    Sep 2012
    Colorado
    Quote Originally Posted by Bob Alfonso View Post
    They are both stamped USA.
    Are you sure Bob as there is no capacity for the outside bulb and they are marked USA inside the bodies
    Clyde Boyer
    Jul 2003
    Santa Cruz, CA
    More specifically Euro 73. I think the addition of the small plastic reflector behind the running light bulb was a later iteration. Clyde, the housing castings were common and will often have USA and Italy cast into the backside. The USA castings for instance have the pegs for mounting the front light separator plate but, obviously aren't swedged because no separator! They don't look modified so, definitely Euro. Also, the snap in reflectors are a different pattern from Euro to US.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Senior Member tcsracing1's Avatar
    Nov 2015
    Somewhere in a galaxy far, far away....
    what is behind the reflector?
    Euro car had white paint there from what i recall?
    www.tcspeed.com
    Thanks Michael I have changed the heading and description
    Clyde Boyer
    Sold thanks Early S
    Clyde Boyer
