Thread: Help..What are these wires for?
    Guys
    For 73.5 CIS
    Can't remember what these wires are for and where they attach.
    They extend from the rear relay panel.
    The black one and the red one ...they are the ones that are hanging
    Ready to install engine but did not see any connection points on engine.
    Please see photos
    Thanks for assistanceName:  IMG_3158.jpg
Size:  120.7 KBName:  IMG_3159.jpg
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Red one is likely for CDI harness.
    Not sure of the black one this late at night... could be a wire to the VR? (DF)
    Timmy2
    The CDI has 2 posts....the front has the 2 brown grounds so could the jack post be for the red ?
    The black is still unidentified ....?
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Use a test light on that red wire and I think you'll see that it is "switched power" I also don't see the engine harness plug going to the CD box, that harness should have the mating connection to your 'red' wire. The black wire may be what Timmy2 said. Is there a wire to the VR terminal of the voltage regulator,can't tell from your picture.
    Ed
    Thanks very much for things to check, will do so and back with findings.
    Appreciate timmy2 and your assistance .
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
