Results 1 to 10 of 10
Thread: Question, banjo horn refurb
    Apr 2004
    35,000 ft
    I found some old threads regarding rebuilding banjo horns, but all the links are long-dead. It was suggested that some other Bosch horn had the same electrical portion that would easily swap onto the banjo horn body. My research shows the banjo horn and the early trumpet horns are not compatible.
    Can anyone shed some light?
    Sep 2013
    Vancouver, WA
    The guts of the banjo and trumpet horns are definitely different but I've not been able to find anything that resembles the banjo horns internals. It sure would be nice if some were available.
    Jul 2014
    Long Island NY
    have a site member here trying to resurrect my banjo horns, and it's a very tall order. Once they are "deceased" very difficult to bring them back from what I'm told. I too would welcome any gut transplants that could work
    Apr 2004
    35,000 ft
    I found some period Bosch horns that seem to have the correct body dimensions, once they arrive, I will document the details if they do interchange, otherwise, I'm following up on a lead of a local guy who can rewind the coils.
    Jul 2014
    Long Island NY
    I would be very interested if those Bosch guts interchanged with the Banjo guts
    I would also be interested in that!
    ditto for me
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Apr 2011
    N.Calif., south of SF
    Ebay has Porsche horns listed (many). The trumpet versions are the black plastic but there is both low and high tone varieties.
    To restore my red trumpet versions I took off the old failed portion and attached to them. Work great.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Apr 2004
    35,000 ft
    The coil/ electromagnet on the trumpet horns do not interchange with the fanfare/banjo horns.
    Apr 2011
    Good to know. Thanks
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
