Thread: Windscreen Washer Nozzles Blocked
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Mine are blocked and would like to know the best way to clear them.
    I have checked the pump and she is pumping great.
    Having sausage like clumsy fingers I don't want to break anything
    Thanks in advance
    Mark
    Mar 2016
    Italy
    Try with a metallic wire inside the water outlet... be gentle.
    Dec 2010
    Southold, NY
    Stick a straight pin into the outlet hole; also the easiest way to adjust the direction of the spray as it gives you a handle to turn the ball. If all else fails take the assembly of the hood and soak it in solvent.
    Oct 2010
    South Carolina
    If clogged with calcium can try soaking in vinegar
