Thread: WTH: Hand Throttle in my 1967 911
    Oct 2010
    Denmark
    I would really like to build in the 1968 Hand Throttel assembly into my 1967 911 , I need offcause to buy the 1968 handbrake assembly together with the throttel hand lever, but what more to get?
    anyone who have done this job , and can share some knowledge?
    thanks
    Lars
    1967 911 Bahama Yellow
    1962 356 TB 6 Slate Grey
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Great question. I would like the answer as well.
    Never done that,,,,but all you should need is the adjustable aluminum collar that goes on the throttle rod, and the plastic lever that goes on the 68 handbrake assembly, that in turn is what pushes on the adjustable aluminum collar.
    Aug 2010
    Colorado
    I'm about to take this on myself for a 69 912 getting a carbed POLO. Mine is fuel injected. I'm also going to use a later brake assembly that has 2 levers so the heater valves can be operated separately for driver and passenger. I'm also doing separate levers for heat on my 67.
    Chris
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Oct 2010
    Denmark
    Hi Chris
    Have you made your own adjuster hole approx 25x15mm in the tunnel? on the 67 cars , this hole is not made? nor the cutout in the handbrake house
    se this link.
    http://forums.pelicanparts.com/porsc...e-lever-6.html
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Aug 2010
    Colorado
    Lars,
    Thanks for the link. I'll read it. The hand throttle will go on the 69 car as it has carbs. My 67 car has full engine management and cold start is done through the ECU. The engine is getting highly modified 993 heat exchangers and a Burns Stainless muffler.
    As both cars are 912's the dual heat levers should be fairly simple.
    Here is a article you might find of interest.
    Chris
    http://www.reseeworks.com/netherlands-article.html
    www.reSeeWorks.com
