Results 1 to 1 of 1
Thread: 911 fan shroud/fan/ pulley and Bosch "built-in regulator" alternator
    Aug 2009
    SF Bay Area
    All in great condition. This unit was removed from my trusty 3.2SS engine after a catastrophic failure of the engine. The engine had a chronic oil leak that the fan sucked up and kept the fan and housing from ever coming close to getting any built up corrosion. The alternator is fairly new and works perfectly. No chips or missing blades and the fan housing is free of cracks. You will need to use plenty of elbow grease to get the nasty buildup of oil and grime from the thing. Actually, I would just install it "as is" knowing that it won't deteriorate. $1,000.00 plus shipping and any fees. I will guarantee this to be in working order and will return your money if not satisfied with my description.
    I did clean up a small section of the fan housing just to show the clean/corrosion free metal. Trust me, this thing is filthy! That is built up crud in the last picture, not corrosion
    Jim
