Hi folks,
Getting ready to drop the engine. How do you disconnect the leads to the reverse switch. The whole fitting unscrews but causes the wires to become twisted. I don't want to pull too hard on the leads.
Tahnks,
Hi folks,
Tahnks,
J P
69 911T 2.4L w' 2.2S/E cams/Webers
You can put a block of wood against the case to give your hand or wrist some leverage. You can try needle-nose pliers, but you'll crimp the wires doing so.
Those switches aren't cheap, so try to avoid breaking the plastic around the wire leads, which is already chipped.
If you're to the point of wasting valuable time, you can decide if twisting the wires, breaking the switch plastic or snipping the wires and moving on is more practical.
Jon B.
Vista, CA
Pins inserted in the switch are soldered onto the wire leads. They should just pull out.
A little knowledge goes a long way. The pins pulled out with no big effort. I'm glad I didn't unscrew the fitting or I would have been covered in trans fluid! I wish the original instructions had mentioned "pins" rather than just saying "disconnect leads". Thanks guys.
J P
Aren't they good old fashioned bullet connectors, somewhere on Porsches since day one?
58 speedster
66 912
67S
73S
97 VW eurovan
1132 honda snowblower
member Jackson Hole Ski Club
They're the same bullet connectors you find on 356s. At least on newer 356s; on my '58 most of the connections are clamped with screws.
A few years ago I had to change that switch on my 911. For whatever reason, the bad switch in my car had "modern" spade terminals and the replacement required soldered-on bullet terminals like JPM's.
I cut off the old connectors and soldered on some bullet connectors I had left over from installing a new ignition switch in my 356A.
It seems every time I have to solder bullet connectors onto wires I have to do it on my back looking up at the wires.
Jim Alton
Torrance, CA
Early 911S Registry # 237
1965 Porsche 911 coupe
1958 Porsche 356A cabriolet
