Results 1 to 7 of 7
Thread: Identify door garnish moldings.
    36 year PCA member
    Dec 2012
    Denver Co.
    I have these garnish trim pieces I am not sure what year they are for. Still are made of steel and has tabs around the door lock that fits in door shell like 65-68 but has a foam core over the steel and then has vinyl glued over it. One off those weird 69 pieces?
    How thick is the padding? 68 rails are padded like the 69-71 rails just less so.
    36 year PCA member
    Dec 2012
    Denver Co.
    It's thick like the pressure formed type later ones. I have some other parts I marked 68 but they are just the steel with no padding and vinyl glued over the steel. I guess maybe they could be late 68/69 like door handles and 3 bar grilles?
    Would still like to have them verified please. Thank you.
    I'm guessing your other parts are marked incorrectly. Door rail progression is:
    65-67: Vinyl hand-wrapped over steel. No padding.
    68: Vinyl hand-wrapped over thin padding over steel.
    69-71: Vinyl hand-wrapped over thicker padding over steel.
    72-73 (and later): Vacuum-formed vinyl over foam.
    If I had to guess based on your photos, I'd say yours were 1968 parts.
    Aug 2009
    SF Bay Area
    Quote Originally Posted by Slcarr View Post
    Those are 68s. The ones you have "marked 68s" aren't.
    Ciao
    Jim
    36 year PCA member
    Dec 2012
    Denver Co.
    Thank you Jim.
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
