Results 1 to 10 of 15
Thread: Clips
    Senior Member tomlu's Avatar
    Jan 2012
    Sweden
    Clips
    Can't find the clips for the square holes in the centre tunnel.
    Where to find.
    Searching for engine # 900889
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Not 100% but I think your after whats called a "speed nut" ,,, readily available, Pelican etc
    Mark
    Jan 2012
    Sweden
    Think I need to takeout the one I have
    for an closer look.
    Mar 2006
    Louisville KY
    999.591.354.02 Should be the part number. I'm pretty sure they are the same as what was used on SC's & Carrera's to mount the front license plate.
    http://www.stoddard.com/99959135402.html
    Tony Proasi
    52 split window coupe
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    Quote Originally Posted by 911quest View Post
    No, those are not the correct ones. Can't come up with the part number off hand, drop Jim at Easy a note, sure he has a bunch. They are a snap in (spring type) clip, nut, fastener thingy,...
    Mark...
    Jan 2012
    Sweden
    Email sent
    Nov 2010
    Glen Allan, Ontario
    Part number is 999.591.329.02
    Todd
    Jan 2012
    Sweden
    Found it
    Thanks for the part number Todd
    Jan 2012
    Sweden
    Aug 2009
    SF Bay Area
    OK, I just went out and collected 3 of them. Now what do do?
    Jim
