Thread: removing head light plug on wiring harness
    Jul 2014
    Long Island NY
    Anybody have any ideas on how to remove the plastic head light plug from the harness (so I can pull it through the headlight bucket). This a 71 targa. Thx very much
    Use a small straight tip screwdriver, tip only a couple mm wide, and looking at the socket opposite the wire entry, you will see a small groove in the socket. That is where the spade end tab snaps up to lock the spade in place. Push the screwdriver tip in and push down that tab. The spade will then pull out the back.
    Jul 2014
    Long Island NY
    Thx as always Ed, are these plugs still available.? I trashed the first one I worked on
    They were last time I bought one from Porsche,,,,,but not sure how long ago Betcha Tom 1394 racing up in your area has some!
    Jul 2014
    Long Island NY
    Worked like a charm Ed, Thx as always
