Results 1 to 2 of 2
Thread: Visual differences....and part numbers
    Between an Alu case intermediate shaft (no bearings) and a later Mag case intermediate shaft w/ bearings...and also the coupler to the early oil pump.
    I'm thinking part numbers would also be helpful. TIA
    Speedo
    registry# 1283
    Oct 2008
    Burford, ON, Canada
    I'd search for "intermediate shaft" and also specifically for poster Jon B.
    Jon has posted lots of good information. Here are a few photos I have collected.
    There appears to be two types of gears for aluminum cases, 3 bolt & 3 pin version and later 6 bolt version. Magnesium case gears are 6 bolt type.
    Note the oil groove in the outer portion of shaft for aluminum case that is absent in the magnesium case version.
