Results 1 to 10 of 14
Thread: What is it and what does it do ??
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Hello all,
    I am wanting to know what the small rectangular black block does that is positioned where the top of the drivers door window frame meets the door opening. There is not one on the passengers side,
    Thanks in advance
    Mark
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    i am just guessing, as you have no pics encluded, but maybe you mean:
    Rubber door stop
    901 531 753 00 / 911 531 753 02
    Installed in early 911 Coupe to prevent wind noises
    by preventing the upper window frame to be "sucked"
    out at high speed.
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
    Feb 2017
    Auckland NZ
    Thanks for that Haul, I figured it was a 'stop' and now know the "why"
    Drivers side only on my 72 ?? was that usual ex factory ??
    Mark
    Jul 2014
    bavaria
    Mark,
    good to know it is the part you where looking for.
    regarding the "usual ex factory" I cannot confirm this.
    Other have to jump in on this topic... and clearify.
    regards
    haul
    erwin_loves_polo
    Should be on both sides.
    Oct 2010
    Denmark
    also on swb`s ?
    1967 911 Bahama Yellow
    1962 356 TB 6 Slate Grey
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    NZ -
    I'm looking for some of those if you have spares - let me know, thanks!
    - Rob
    Feb 2017
    Auckland NZ
    I have spent time looking at photos of mainly 70-73 cars excluding Targa of course and these "stops" appear to be a random item. Admittedly the photographers dont exactly focus in on this area of the car.
    Some have them but most do not have these installed which leads me to think that they were not a factory fitted item.
    My 72T has one on the drivers side only and I get zero wind whistle on this side as well as zero on the passenger side which does not have the stop.
    The fitting these obviously requires drilling and affixing with 'self tapping' screw or the like.
    Perhaps as an assumption my drivers door required one as it obviously gets opened and closed more often than the passenger side.
    I will attach some shots, 1 being with door closed and other with door open. This has clearly been on the car for some time and has slightly distorted the door seal but as mentioned there are no air leaks or wind noise so Im happy as I cannot stand 'whistle'
    MarkName:  IMG_2331.jpg
Size:  47.9 KBName:  IMG_2332.jpg
    Feb 2017
    Auckland NZ
    Not too good on the old neck those shots,,, soz for that
