Thread: 69t, found some kind of switch / Relay Help?
    Hello,
    Found a black switch doing nothing under the dashboard near tachometer on my 69t?
    It have wires going to it near the ignition but nothing connected to the 4 spade connectors
    from bulkhead side.
    What is this normally used for?
    I have 2 pull switches which are redundant and wondered if for fog lights?
    Would this be a standard factory fitting for MY 69 or would this be installed at dealer from new or retrofit?
    [ATTACH=CONFIG]423117[/ATTACH
    Thank you
    Not original to a 69,,,,some one has added this.
    Thanks Ed,
    With your past experience would you say it could be a switch for a set of fogs or an electrical aerial?
    I think there is another next to it out of picture...
    Thanks lee
    A set of lights most likely,,aerials are usually powered by a switched on radio.
    Looks like domestic alarm crap or something like....certainly not original.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
