Results 1 to 2 of 2
Thread: FS: 1969 oil tank
    FS: 1969 oil tank
    $500 .. No leaks. Original part from my 1969 Porsche 911. I am the original owner of the car. I recently had the tank checked, sealed, and pressure tested by Moyer Fuel Tank Renu in Pennsylvania ( you can google them to check their site and service), who sealed the outside with this thick protective coating. The tank works great and does not leak. Comes with a brand new cork gasket for the oil level sender unit. Also, has a rock protection plate on the front to prevent rocks that kick up from the rear wheel from hitting the tank. I am doing a complete nuts and bolts restoration on my car and wanted a brand new tank, so don't need this original one anymore,
    IMG_20170523_191959.jpgIMG_20170523_191734.jpgIMG_20170523_191753.jpgIMG_20170523_191942.jpg
    still available. Works fine. I promise doesn't leak. it just doesn't look so pretty.
