Results 1 to 8 of 8
Thread: Cannot open my glovebox anymore (key turns/open/lock)
    Jul 2006
    Switzerland
    My 71T is always in good shape, opened the glovebox recently...and today cannot anymore.
    Key does open and lock the knob but when I turn/open and pull, it does not open.
    Assuming the pin is broken? Any help to proceed, thx
    Registry member No.773
    I assume you checked that the lock tightening ring hasn't loosed and just rotated the lock so it wont open ?
    Jul 2006
    Switzerland
    Will check again but usually i can pull it open w the key when turning..i own the car since 2005 so ive done it a hundred times. Assuming its a pin which goes into dashboard underneath and stays locked even the key/knob is opening.
    (Knob does has a rubber seal around) anybody? Thx Chuck.
    Jul 2006
    Switzerland
    Thx for the link, guess I need to take off the box from behind to then get access to the door.
    Jul 2006
    Switzerland
    Bingoo!
    I managed to open it in 10seconds, with an old modified/cut creditcard.
    Cut it, slided it behind the pin/lock, pulled and opened. No damage no nothing.
    The tip comes off a pelican thread and where both creditcard cutting and trick is explained.
    Thanks ToddSimpson so much for all this, very greatful:
    http://forums.pelicanparts.com/porsc...d-what-do.html
    GREAT idea !!!!!!! Thanks Karim and Todd.........
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    I would have used my wife's current card.
