Results 1 to 10 of 10
Thread: Help: first gear won't stay in ...
    Hi everybody ... yesterday I was out driving pretty hard with some friends and while negotiating a hairpin, the first gear went out by itself, with all the mess you can imagine.
    Since then, it only stay in when gently applying power with the clutch a little engaged, otherwise it will go out. Trans is a 915/60 with factory short throw kit. All the other gears have no problems.
    What might be the reason?
    Thanks a lot.
    Instagram
    Twitter
    Mar 2016
    Italy
    Quote Originally Posted by Biancaneve View Post
    Since then, it only stay in when gently applying power with the clutch a little depressed, otherwise it will go out. Trans is a 915/60 with factory short throw kit. All the other gears have no problems.
    Thanks a lot.
    You probably have to rebuild... but check your shift coupler first
    Thank you!
    Instagram
    Twitter
    Aug 2010
    Colorado
    Hairpin turn? Transmission mount deflecting from old bushings?
    Chris
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    You may have exploded first gear synchro band.
    Banned
    Nov 2004
    Scottsdale, AZ
    Drain the oil and make sure you're ready to capture pieces.
    Or buy a bungee cord.
    Pops out of gear, worn operating sleeve, synchro and coupling gear, a rebuild will take care of it.
    A 915/60 is a 77 transmission, so this is probably about "Fiona"...
    Do you have any receipts for transmission work on Fiona? How long have you owned Fiona?
    You should do these basic things first, before pulling Fiona's transmission...
    1) Eliminate the possibility that this is a shift linkage issue.
    2) Drain the transmission oil, and check the drain plug magnet for unusual bits. Check the oil for metallic glitter.
    3) Remove the cover plate from the bottom of the transmission. Check the guide fork attached to the cover plate, and confirm that it's not loose.
    4) Report back.
    Jon B.
    Vista, CA
    Apr 2008
    Virginia's Blue Ridge
    Wow! Gotta love this place. Mayo, Beck, Ledbetter and Bunin all responding in one thread asking for help. As good as it gets.
Tags for this Thread
