Results 1 to 10 of 18
Thread: Running 6-7° deg hotter right sider weber carbs
    Oct 2010
    Denmark
    why does the right side webers run 6-7° deg hotter than the left side? messured with ifr - sender on idle and during cool down 0- 60 min engined turned off
    rg.lars
    1967 911 Bahama Yellow
    1962 356 TB 6 Slate Grey
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Never measured that,,,,,perhaps because oil cooler on that side?
    Oct 2010
    Denmark
    valve cover top/bottom have the same 6-7° increse
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Banned
    Nov 2004
    Scottsdale, AZ
    How about exhaust temp? Similar percentage difference?
    Oct 2010
    Denmark
    yes.... engine is running great though, no popping , no exhaust leake. nice sparkplugs , parts klassik cdi
    chasing the hot start fuel boiling issue, perhaps from right carb..
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Are you running phenolic blocks, or just regular gaskets? Perhaps a material difference between the two sides, if running the spacers?
    1969 911 E #824
    Oct 2010
    Denmark
    yes I have the spacers fitted on both sides, same material
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Banned
    Nov 2004
    Scottsdale, AZ
    6-7 degrees is a pimple on a gnat; not enough difference to matter. Your problem is something else.
    Octane and age of the fuel you currently have in the car?
    Ultimately the question is what is the octane now?
    Oct 2010
    Denmark
    new gas shell 99 oktane + lead additive
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Banned
    Nov 2004
    Scottsdale, AZ
    99? Some nice tonic there.
    Why do you think it's a peculation issue?
    Are you sure your points aren't closing up?
