Thread: Front sway bar drop links
    I am installing a through the body front sway bar on a 1970 911
    I am not sure how the sway bar links are suppose to go.
    The stock links are the same for R & L side.
    One end of the links is straight & other end is off set.
    Does the straight end go into the sway bar arm & off set to the A arm?
    Thanks Bernie
    No, the bent end goes in the sway bar arm and leans out, the straight end goes in the A arm.
    Think you can see them here
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Thank you
    I have them backwards.
    I was not sure with the front end jacked up.
    Bernie
