Thread: 1973.5 CIS Mixture adjustment
    Senior Member Gumby's Avatar
    Jul 2006
    Pine Bush NY
    Hi,
    I want to adjust the mixture on my 73.5 CIS injection
    but the only book that I have has zero information!
    I think there is a hole that you can do this with a allen wrench that is supposed to have a plug in it
    when I slide the allen wrench into it does it contact the mixture arm?
    and if so which way do I turn it ( the motor sounds rich ) also is there supposed to be a plug is this hole?
    Information and education will be much appreciated.
    Thanks, Ron
    Ron
    1973.5 911T
    1974 BMW R90/6
    1986 Carrera, Plan "B"
    1987 BMW K100RS Motorsport
    2004 BMW X3 6 speed manual transmisson
    There usually is a protective plug. Right rich, left lean with a 3mm Allen. With the air filter and cover off and the engine idling, reach in and gently push up on the arm you will see (looks kinda like an elbow) or with your finger in the elbows crook pull down. If engine smooths out pushing up the mixture needs to be richer. If you pull down and engine smooths out it needs to be leaned out. These are the crudest adjustments, and test equipment should be used. There are many adjustments not discussed here, sensor plate drop under pressure, plate centering. System and control pressures. 73 was a first year for the CIS, and many improvements were made over the years to correct the defencies of the early systems. Gordon
    Jul 2006
    Pine Bush NY
    Wow , lots of great information, Thanks Gordon
    This is why I joined The Early 911 S Reg!
    Ron
    1973.5 911T
    1974 BMW R90/6
    little T handle for mixture adjustment. good luck.
    Jul 2006
    Pine Bush NY
    Ron
    1973.5 911T
    1974 BMW R90/6
    Jul 2006
    Pine Bush NY
    Update!
    Turning the mixture allen screw had no effect..so I sent the car off to the shop that has the equipment and knowledge to correct the running condition
    Ron
    1973.5 911T
    1974 BMW R90/6
