Thread: steering wheel vibration
    Jun 2011
    Bellingham, WA
    what is the best way of checking to see if I need to replace my front struts. They are not leaking. I have a vibration in the steering wheel at 70+. Wheels rebalanced several times. I am using the original steel wheels
    If I have them removed to check, I assume that they must be replaced
    Loose tie rod ends, loose wheel bearings, bent wheels, tires with excessive runout, and improperly balanced wheels can also cause the vibration.
    Have you got good tyres http://www.longstonetyres.co.uk/page...-porsche-tyres
    70mph that does sound like wheel balance.
    Dec 2010
    Southold, NY
    Swap wheels front to rear.
    Jun 2011
    Mound, Louisiana
    Quote Originally Posted by ejboyd5 View Post
    There is a good idea. Also rig up something to check run out, and spin them before the swap.
    Paul Harrop 12.5% German.
    Early S #2059
