Results 1 to 10 of 13
Thread: Marchal Amplilux interior cleaning
    Senior Member ghalperin's Avatar
    Apr 2014
    Newport Heights, CA
    I just installed a pair of NOS headlights and there is a slight haze or dusty film on the interior of the lens. You can see the milky haze in the photo. What can I do to clean this, without disassembling them? I was thinking of swirling alcohol inside.
    Glenn Halperin
    Early 911S Registry Member #2956
    Sep 2009
    UK
    If the lenses are fixed the same as the cibie biodes, i would remove them and do the job right.
    Apr 2014
    Newport Heights, CA
    They are glued on, but I'm concerned with damaging them in the process. Is there a recommended tool that is used?
    Glenn Halperin
    Calling Mr. Audette...
    Peter Kane
    '72 911S Targa
    Jun 2003
    Bend, Oregon
    Glenn...
    Removing the lenses is doable but it can be tricky. My experience with the various early dual reflector headlights such as Ampliluxes, Cibie Bi-Iodes, Carrellos and the like, is that the lenses were affixed differently at diferent times, even by the same manufacturer. I've successfully removed the lenses on many of them, but I have not been able to remove the lenses on a number of them. For example I'm working on a set of Carrellos right now and finding it difficult going.
    I use a curved pick, a small bladed screwdriver, razor blades and Goof Off.
    Good luck!
    Cheers,
    Loud lederhosen saves lives hoffman912's Avatar
    Feb 2003
    what do you reattach with?
    Harry Hoffman
    356 Registry Member #36691
    Sep 2009
    UK
    I have used a heat gun and acetone to liven up the old glue. I then use a stanley blade. I bond with clear two pack epoxy resin.
    I don't want them popping off over a speed bump.
    Apr 2014
    Newport Heights, CA
    Thanks for all the tips. The glue isn't hard. I'll give it a try at disassembling them. I just got new tips for my Snap-On picks. Epoxy sounds a little too permanent.
    John, what do you glue them back together with?
    Glenn Halperin
    Jun 2003
    Bend, Oregon
    I secure them with Permatex 85913 Clear RTV Silicone Adhesive Sealant, same thing I use on SWB turn signal lenses.
    Apr 2014
    Newport Heights, CA
    Quote Originally Posted by jaudette3 View Post
    Thanks, that sounds a little easier to get apart, for next time.
    Glenn Halperin
