Thread: 1972 REAR SWAY BAR Help
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    I need to replace my rear sway bar bushes and am confused, (seems to happen more and more these days)
    It is a factory fitted bar on my 72T.
    There appear to be both 15 and 16 mm rear bushes available and this is my issue. I assume the Diameter is the OD (outside diameter) of the bar itself but am flummoxed. Did the factory make and fit rear sway bars with only 1mm of OD difference??
    I understand that I need 4x bar bushes and 2x bar link to ball pin bushes but am seeking clarity on the Bar Bushes required.
    Many thanks in advance
    Mark
    Mark,
    If it's a factory mounted rear sway bar it should be 15 mm ... it should take 4, 15 mm bushings...
    Feb 2017
    Auckland NZ
    Thank you Chuck.
    COA states "Front and Rear Sway Bars" so I will roll with 15mm
    Mark
