Results 1 to 2 of 2
Thread: Synchrometer help
    Synchrometer help
    I'm looking for a STE Synchrometer for my 1966 911 Solex carbs. I located two flavors, BK and SK. Which one should be selected? Thank you.
    The SK Synchrometer fits airhorns from 1 5/8' (39mm) to 2 1/8' (55mm) in diameter, including the 40, 42, 45, and 48mm sidedraft (DCOE) and downdraft carburetors. The STE SK Synchrometer measures flow mass from 1-30 Kg/Hour.
    The BK Synchrometer has a larger airhorn adapter and is designed to flow more air than the STE SK. It fits in airhorns from 2' (51mm) to 2 5/8' (67mm) in diameter.The STE BK measures flow mass from 1-35 Kg/Hour
