As previously posted, I was/am having trouble getting the correct combination of rear engine cover/tin, chain box covers, and engine crossbar "console." I was not aware of the number of possible configurations and how the console, chain box covers and rear engine cover interacted with one another. Hopefully, this thread will move us closer to a full answer. I am especially interested in hearing from Jon B and Frank Beck, who offered great information in the original post.
First, it appears that there are at least 3 versions of the "console" which fastens the engine to the crossbar, as was discovered in the original post. The earliest version of the console (the actual dates are not clear to me) is narrow at the point where the engine tin fits (~6 1/4"). The later version of the console (alleged to be ~MY67) is ~7 1/4" where the tin fits. According to sources, there is a later version (suggested to be ~SC) which is wider, still. Since the rear engine cover/tin has to fit around the console, the width of the console it pretty important.
The photos below show three versions of the rear engine cover (I am told that there are more versions of the engine cover, if that matters): a very early version with an indentation for the pierburg fuel pump on the driver side; a '68 version to accommodate the smog pump pulley on the driver side; and a later version (of unknown provenance). When placed side by side, it is easy to see that the very early (pierburg) rear engine cover has a substantially narrower opening for the engine console (~6 1/4"), while the '68 and later engine covers have wider (~7 1/4") openings. Clearly, the size of the center opening of the engine cover has a direct relationship to the correct rear engine cover.
Unless there is another configuration of a SWB engine cover with a wider opening to accept a wider console, the (pierburg) engine cover will only fit around the narrower (very early) console. Since my engine has the wider, MY'67 console, only the two engine covers with the wider opening can fit around the console. Can anyone provide photos of a SWB rear engine cover with a wider console opening? Does such a beast exist?
What is less obvious is the cut-outs along the leading edge of the rear engine cover. Those cut-outs are obviously configured to fit over the engine castings at the point of interface, including chain box covers. If you look carefully, you will see a semi-circular cut-out on the passenger side of the early/pierburg engine cover. (A similar cut-out was made (by me) in the later cover, in an attempt to achieve a quick fix for the fitment problem.) You can see that the semi-circular cut-out does not exist in the '68 version of the engine cover, and therefore will not fit correctly to the rear of my engine.
As the next photo shows, the passenger side chain cover has a bump in the casting, and my engine cover needs to accommodate that bump in order to fit correctly.
What is not clear to me is whether the chain box cover in the photo is correct for a SWB car? I fully intended that I was not going to use the '68 smog equipment, but I did not consider the details related to fitting the engine cover, especially at the level of detail of potentially different chain cover castings. I am 100% certain that the engine is fully functional and prepared to perform. But at this stage of the project, we are into tertiary-level issues that might be cosmetic only.
There are two new questions for this post. First, do any of you (especially Frank Beck and Jon B) have photos of other versions of rear engine covers that might accommodate the chain cover AND the wider console?
Second, do any of you have additional information related to the chain box covers? I'm interested in provenance for chain box covers related to the SWB engines? Photos showing changes in chain box covers for SWB engines would be most welcomed. Also, photos showing the differences between normal, 'S' and 'T' engine chain box covers would be appreciated.
Thanks, as always for educating me/us.
