Thread: Cibie 7's
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Cibie 7's
    Anyone know if these are the correct units to fit Porsche /Hella seal beam light housings? Thanks, cliff
    Sep 2009
    UK
    They certainly look right from the back. Flip them over.
    Looks like wiring them in will be a little tricky, can't use the standard three pin plug.
    Its more like adapt to 911. The protrusions on the perimeter dont fit the Hella sealed beam rings properly. Correct biodes are 170mm. 180mm biodes adapt to 911 covered headlights fairly easily and are much more plentiful coming from Citoens. I cant quite figure out why Cibie adds fluting to the left side for lhd lights and Bosch adds fluting on the right side for lhd. This is a rhd 170 biode, Id like to trade it for a lhd.
