Results 1 to 10 of 17
Thread: 16" wheels on a 911 S LWB
    Jun 2011
    Mound, Louisiana
    I bought a set of 6J and 7J 16s just for the 6's. I bought one more 6J that was perfect, then the other that was advertised as a 6J, turned out to be a 7J.
    So being the impatient person I am, as the car is running perfect, I was thinking about running 205/55/16 all the way around. The 7Js would just be spread it a bit more. This would help the weight bias? And fit under the stock fenders with out a BFH mod? I remember Richard Newton doing to this on his I think, and I never asked him about it, RIP.
    Thanks!
    Paul Harrop 12.5% German.
    Early S #2059
    Dec 2008
    Black Mountain, NC
    I am running 215-50 -16 Dunlop Direzza's on my 71 Targa, mounted on 6 x 16 refinished SC wheels. The Dunlop has a bit of an extension at the bead to set the tires to a wider profile as well. Some like them on early cars, some don't, I do. I also have same wheels finished by Al Reed on my 66 912 coupe on 205-55 16's
    Jan 2011
    DFW TX
    The 6x16 will work fine, same offset as the 6x15. The 7x16 will be a problem in the rear (same offset... outward as a 7x15), requiring either luck or lots of negative camber on a narrow body car to prevent rubbing (or an elevated posterior, that works too).
    Aug 2010
    Colorado
    You can refinish the 16's to get a different look. I had Al Reed do these around 2010. He said he had never been asked to do this at that time. I had him just paint the flat area between the spokes and don't go up the outer rim.These are on my SWB car. 195/55/16's on 6X16's.
    Chris
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    I am running 16" 6's & 7's with 205/50's on my 70T with no problems and no modifications.
    Mark..
    Oct 2010
    Southern Ca.
    I don't get it . If you want 16's why not get an SC ? I think they just look wrong on an early car .
    Aug 2010
    Colorado
    More tire choices to choose from. I've had my car at vintage Porsche events and nobody even noticed they weren't 15's.
    www.reSeeWorks.com
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    Quote Originally Posted by Richy View Post
    Personal preference of course, but I disagree. I think the 16's fill the wheel wells better, 15's look to small to me. If I was doing a concours car, then of course 15's but I prefer the 16's for a driver / hot rod.
    Mark..
    Better tire selection for 16's and size difference doesn't really pop out.
