Results 1 to 10 of 14
Thread: Installing rivets/door pockets hinges ?
Size:  69.2 KBI am trying to install the plastic hinges and rivets . All part of the SM kit.
    I have used my tool in past but it does not seem to be able to pull the rivet to a flat position.
    See photo of the rivet position and tool.
    Is there a different hand tool, who has been successful and process?
    Thanks for assistance
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Jul 2014
    Long Island NY
    Hey Frank, a regular POP rivet would do it I would think? Is that SM kit, the CarPoint kit or is it one they have sourced on their own.?
    This is SM kit....thanks for idea on pop rivet.
    Just want to make these work till I get worn out with efforts..
    Must be a way ,maybe my tool is incorrect?
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    On that soft material you should use an aluminum washer on the rivet. Also don't do it in one pull, use several shorter pulls and reseat your tool at each pull.
    David thanks ..... will give this a try today
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    ⇧ What he said!
    Early S Registry #235
    rgruppe #111
    Sit hot
    Also thanks ...all confirmed
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    So tired to install from both sides of pocket not catching both sides ...it will only catch one side pulls them the other side.
    I believe the rivet should be longer so as it's pulling it will be getting fatter as it approached the washer so it will catch.
    Has anyone used the SM kit and how did they get the rivets installed in hinges for front pocket. Not ready to attack the rear flip pocket yet.
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    We've done a bunch of these with no issues. If you'd like, shoot me a PM and I can get you on the phone tomorrow with the guy at my shop who's been doing them.
    That is fantastic....I will send you PM
    Thanks a 1/2 million.
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
