Results 1 to 2 of 2
Thread: FS: 914-6 GT oil system
    Try to find all these parts to match my price.
    You can't. You won't. I dare you!
    I've been to that place and you don't want to go there
    Just buy mine and you will have the complete setup, no waiting!
    914-6 Oil tank (new - Porsche)
    GT Oil tank filler neck 80mm - press bypass fitting - repro (Sierra Madre)
    GT Oil tank filler cap 80mm - Blau aluminum outer, steel inner, with fin
    GT Oil filter console - early 911S magnesium
    GT Oil filter console spacer - repro (Barry Pantzer)
    100mm allen head bolts - new zinc plated steel
    GT Oil thermostat - cast with mounting tab and 26mm ports
    26mm-26mm male fittings (2)
    26mm-30mm male fittings (1)
    20mm-26mm male fittings (2)
    GT Oil pressure relief valve - aluminum repro (JKH)
    GT Oil lines to front cooler - brass repro (JKH)
    GT Oil line solid T-tank-return-pressure relief - repro (JKH)
    GT Flex oil line hose - 26mm new (Cohline)
    GT Flex oil line hose - 30mm new with green tracer (Elephant)
    30mm 90 degree oil line fitting (2) - new (Elephant)
    30mm straight oil line fitting (2) - new (Elephant)
    GT Argus short line
    GT Oil catch tank (67 912 Washer Bottle)
    GT Front oil cooler shroud - steel reproduction (mittlemotor)
    30mm 90 degree Oil line fitting - used TCH Aluminum
    26mm 90 degree Oil line fitting - used TCH Aluminum
    26mm 45 degree with 30mm T - steel reproduction (JKH)
    Red Purolator filter stamped with Porsche
    I will sell the kit for $9k.
    Or $8k if you don't need the brand new 914-6 oil tank.
    Pics posted on bird board here:
    http://forums.pelicanparts.com/porsc...il-system.html
    cheers,
    dug
