Thread: Engine Revs/Rpm Increase when Clutch Disengaged while driving
    Hi All
    Anyone had the lovely experience while driving where you disengage the clutch (press the clutch pedal) when shifting up/down and the rpms/revs on the engine increase? This only happens when driving the vehicle as if I depress the clutch when the car is stationary in idle, there is no rpm increase.
    I have already cleaned and examined the idle control valve. I have also checked the bowden tube on the clutch cable and it only slightly rubs the throttle linkage on the bellhousing. I dont think it is enough to create an issue.
    Could it be a vacuum leak?
    Faulty deceleration valve?
    Possibly the throttle and clutch cable are twisted in the tunnel?
    I am running a 993 Varioram with a 915 Euro transmission in a 1970 chassis. Lightened flywheel and clutch. Do you think I need to tune the ECU for this?
    Any thoughts, feed back, or advice would be greatly appreciated as I am stumped.
    Jason
    Check the cables in the tunnel...clutch and throttle...they could be binding together at some point. Know from it happening to me.
    Dec 2010
    Southold, NY
    Unsure as to what distributor may be involved; perhaps the advance weights are sticking if so equipped.
    Issue resolved. Cables rubbing at pedal box and Bowden tube resting on throttle linkage at the bell housing.
    Senior Member michaelaiellosr's Avatar
    Apr 2014
    New York/Florida
    You might be interested in this thread
    http://www.early911sregistry.org/for...rottle+linkage
