Results 1 to 10 of 13
Thread: 911l lsd?
    May 2013
    Canterbury, UK
    911l lsd?
    How do I tell if my 1968 911L sportomatic has a LSD or not?
    Early car manufacture date November 1967.
    Can anyone help please?
    Thanks in advance
    Jack up car in rear, rotate a rear wheel, while doing that have a friend try to hold the other wheel, if he can you don't have a LSD.
    Quote Originally Posted by gduplock View Post
    I don't believe that a limited-slip differential was an option for a 905 Sportomatic, and I'm not aware of one that was or is a direct fit.
    Differentials were not interchangeable between Sportomatic and manual transmissions.
    Jon B.
    Vista, CA
    Banned
    Nov 2004
    Scottsdale, AZ
    Sporto LSD...?
    One of the main goals in a community is civility. - Frank Beck
    Banned
    Nov 2004
    Scottsdale, AZ
    I thought I was being civil?
    Good thing I didn't post what I wanted to say.
    At the time, many people ordered limited-slip differentials for better traction in poor driving conditions, and not for sports or racing purposes.
    Even so, I've never seen a factory reference for a 905 Sporto LSD.
    Jon B.
    Vista, CA
    LSD Identification
    . . . How do I tell if my 1968 911L sportomatic has a LSD or not? . . .
    Dunno when this practice started/ended but --- here's another post . . .
    . . . posted questions about transmission numbers in the Technical Info section:
    http://www.early911sregistry.org/for...ission-Numbers
    The consensus is that the |10 stamping means that the trans is fitted with an LSD --- which coincides with the CoA for this car . . .
    Oct 2008
    Burford, ON, Canada
    I agree with Jon; there was no LSD for the Sporto trans.
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    And the 911R sporto?
    Quote Originally Posted by uai View Post
    Uli, did a 911R have a stock production Sporto transmission with an off-the-shelf LSD? You tell us...
    For a special application, it might be possible to modify an existing LSD to fit a Sporto, or modify a Sporto ring gear, or have a special LSD housing made to fit a Sporto.
    That's all assuming that there was a 911R with a basic production Sporto and an LSD.
    Do you have a reference from a factory manual, parts catalogue, bulletin or sales brochure that an LSD was an option for a Sporto transmission in 1968?
    Can you point us to a source for an aftermarket 905 Sporto LSD?
    Jon B.
    Vista, CA
