Thread: 1967 911 - Material behind lower rear window corners causing rust
Threaded View
    Apr 2013
    Northern California
    Upon stripping back seat area and removing rear window, preparing for body restoration I found rust in both left and right lower corners of the body. I appears insulation was installed (factory?). If the window leaks water into this area the material hold the moisture causing the metal to rust.
    Any thoughts on what should I replace the material with or even if it is necessary?
    See attached picture.
