Results 1 to 2 of 2
Thread: Weber jetting 73s
    Apr 2012
    SE PA
    Weber jetting 73s
    I bought my car in 1987 and it didn't run right then. Fast forward to now and finally getting car together but runs bad so I want to send out injection pump and injectors to have them gone over. I would like to use webers that I have till I get injection back which could be winter. I have found info on jetting with 32 mm venturies but would like to use 34 because I have them. Its a total stock 73S with a stock muffler so anybody have jetting info it would be great. Thx
    Since the larger venturi will delay the low pressure signal that allows fuel to be drawn from the emulsion tube usually a slightly larger main jet will be required, like from a 135 to a 140. In more extreme cases you might need a smaller air correction jet, but that's not likely for your application. There is a Weber graph that shows the theoretical size, but I don't have it here at home.
