Results 1 to 9 of 9
Thread: Hangers rear/engine wall
    Nov 2016
    Munich, Germany
    Hi all!
    After having stripped the lightweight carpet I found out that someone has ripped off the hangers (I hope that's the correct word for it) where the rear-wall cover panel goes.
Size:  125.4 KBName:  IMG_20170809_164822.jpg
    Are there any repro parts I could weld in or would I have to cut them by myself?
    thx in advance,
    Tom
    Tom -
    Same on my Ltwt. I think that's the factory's way of saying nothing goes there.
    - Rob
    Feb 2007
    Cheshire, UK
    They were removed by the factory on my T/R, the car had lightweight carpet instead of the usual parcel shelf and trim bar:
    Tim
    Early 911S Registry #1167
    Nov 2016
    Munich, Germany
    thx guys for your replies.
    Seems like your cars came as lightweights from factory. My 1970 2.2 S was (at least from the COA) M470 equipped. So I assume it originally had all the "E"-standard covers installed.
    At some point later in time the then-owner decided to "upgrade" the car to a more race-like look and pop in some ltwt carpet. Of course for that reason the 4 upper "standers" and the 3 "hangers" on the back wall had to go.
    Since I do want to get the car back to a M470 standard I need the fixation points to get the parcel shelf & trim bar properly installed.
    Sadly those parts don't show-up on the parts catalogue. Even worse that I have no clue what they look like to have them rebuilt...
    Restoration design.
    PP227
    PP221S
    probably can get from Sierra Madre as well
    Membership #3255
    301022
    revivem.co.nz
    Feb 2007
    Cheshire, UK
    Hope these help (photos from a '68T). I am afraid I don't know if lwb were the same as swb:
    Tim
    Quote Originally Posted by Bantam View Post
    If it helps, I recently installed the interior in my 70-S and these attaching points seem identical to what I have
    Nov 2016
    Munich, Germany
    Guyz, you are the best!
    That was exactly the information I needed. I ordered with restauration parts. Let's see if their quality matches the pricing. I'll keep you posted.
    Have a nice week-end.
    Tom
    Nov 2016
    Munich, Germany
    Ivan,
    PP221S is correct, but PP227 is the bracket on top of the parcel shelf where the l&r screwed-on brackets go. Just for the records.
