Results 1 to 8 of 8
Thread: SWB battery tray
    Aug 2011
    Virginia Beach Va
    SWB battery tray
    I need some help with some pictures? We have the suspension pan mounted from restoration design in a SWB 1967
    Installing th battery tray is next on the list
    Can I get some pictures of the mount points an for the rubber strap that holds Down the battery?
    We are using the Restoration design suspension kit which has the battery tray with one of the strap mounting point but where does the other end of the strap attach?
    Thank you for any help ?
    Also in the same area does anyone have the correct placement for where the washer pump bracket go?
    One more item is the washer bottle mount does the front tab of this mount attach to the latch panel?
    Thank you
    Doug Lehman
    Member #2825
    1966 912
    1978 911SC Targa fun in the sun
    Aug 2011
    Virginia Beach Va
    Is any one making this part ?
    Doug Lehman
    Member #2825
    1966 912
    Had to make mine as the old clip was rusty cut, drill, file - if no one else chips in I can take a pic with ruler next to it so you can scale it off to get shape.
    Membership #3255
    301022
    revivem.co.nz
    Aug 2011
    Virginia Beach Va
    That would be great. You would think someone would have made this already.
    Doug Lehman
    Member #2825
    1966 912
    OK will do tomorrow - might evn dig through the box of rusty bits (its a big box and a small part)and see if the old one is there to draw around.
    Membership #3255
    301022
    revivem.co.nz
    Here you go, dug out the old clip removed it and straigtened it out for you.
    Membership #3255
    301022
    revivem.co.nz
    Aug 2011
    Virginia Beach Va
    Quote Originally Posted by Ivan Fuller View Post
    Thank you so much !
    Doug Lehman
    Member #2825
    1966 912
