Thread: Before you try to fit o/g Porsche 914 424 016 02 gearshift lever...
    Nov 2016
    Munich, Germany
    ... I'd suggest you inspect it thoroughly right at your parts dealer's location. This will save you some hassle.
    I bought 2 original Porsche levers in the last 7 days just to find out (after fitting them) that the lever is not properly pressed onto the hemispheric ball that goes into the cup of the bracket. After install the lever was turning round with little drag. The ball stayed where it belonged due to the slot on the right side.
    I guess it's not worth mentioning that the o/g gear knob wouldn't fit properly either.
    Not exactly what I'd expect from an o/g part for a rough 160'ish Euros...
    Sent you a private message
    Nov 2016
    Munich, Germany
    Why has this thread been moved?
    The part is for early 911's though the part number beginning with 914 would let one assume else.Name:  shifter.jpg
    I thought the general/ technical section would be the place to post it, wouldn't it?
    I stand corrected...
    Peter Kane
    '72 911S Targa
