Okay , My car a 1966 Porsche 912 is in line at the sandblaster in NC ,to get the old girl to bare metal.
Dave Miller has cut out the obvious parts that would have been a waste of sand to clean up.He cut out the suspension pan, cross brace, and front wall of the trunk. I will get a list of parts needed after He has seen the car blasted.
Josh made and installed seals for the torsion tube. removed, bagged & labeled the few remaining parts,I must had left attached to the body then sealed the tubes & conduits, and masked the ID plates.
Finally after 2 years of it sitting in my shop.it is in the hands of a great shop!
Here is A little history ,I was struggling over my approach of taking the car down to bare metal. I had taken most of the rear end undercoating And stripped the fenders rear quarters with a combo of heat gun,scraper,wire wheel,paint remover,Mapp Gas . Did I mention I was struggling with the whole idea
Of sandblasting.I looked into everything that I could get good intel on ;having the car stripped with the guy in MICHIGAN that cooks the car body in a parabolic oven,chemical dipping then an ecoat, I then started looking into the dustless blasting (which after looking closer into it this type of blasting is water and sand which the guy was honest and told me that the it would be almost impossible to get the wet sand out to the crevices. ) I look into dry ice blasting for a minute but could not get with anybody that did this type of work. I believe that this could have been an option but was unsure of it getting all the rust away.i saw videos of water blasting which I thought was way cool but where is a good water blaster when you need one.
Anyway I am now at the point where The struggle is real. I need help from all who can.
I know I am going to need to get a
Front slam panel(front partition wall )
Suspension pan,
Pan reinforcements straps
Ballery tray
Gas tank support
Two hook
front floor(I may not need the whole thing but that I will need some),
rear parcel shelf (the part closest to the window),
the bottoms corners of both lock post.
This much I know, after the blasting
I may need both latterial gas tank supports and
two bearing brackets,
I have personally seen kits of the suspension pan from RD in Canada.
i know a few of the US Vendors are bringing in stocking from them as well.
I was looking at Stoddards pan and they say it has
SIC-501-580-20 Front Suspension Pan Repair Panel for 911 912 1965-1973. Correct Early Stamping without Drain Hole/Impressions
I have not seen this pan so I can't compare it to the RD pan. Does anyone know which is more accurate for a 1966 MY ?
i am also interested in feedback on the different manufacturers of the front half floor pan the one that stoddard has seems to have more material in the front than the RD product has. and the stamping looks a little different,
SIC-501-937-00 Front Floor Pan Half Fits 911 912 930 1965-89
which one in your opinion was best for a 1966 MY.?
The front gas tank support and battery tray is another
KURT at Parts Klassic has the Tasker with the battery tray already welded in
Then of course Stoddards has theirs ...
As for the front latch panel I do not believe anyone but danske makes it currently.
Please correct me if I am wrong.
What about the appearance of the two hook is there one out there that looks more accurate?
If you have any insight or recipe as to mixing and matching these parts to make the closest recreation from all these parts that are needed.
Please share your first hand experience and let me know what has worked best for you if you are familiar with the ever changing world of SWB sheet metal reproductions.
