Results 1 to 7 of 7
Thread: WTB: 915 mag case trans 1972 - 75
    Jun 2016
    Texas, USA
    Wtb: 915 delete
    Delete
    Thanks!
    Aug 2009
    SF Bay Area
    You should narrow down your year preferences if you want a working speedometer and axle output flanges that will mate up with your current axles.
    Jim
    What Jim said, plus the R&P changed from 7:31 to 8:31 in 75, so the gearing is different. In 76 the factory went to an electric speedo which would require a different instrument in addition the R&P. You should look for a 72-74 tranny.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    Jun 2016
    Texas, USA
    Thanks for the info. I could deal with either gear ratio, but I should have the correct speedometer drive. My current axles have the four bolt flange on the transmission rnd, when did that end? If needed, I have both the 4 and 6 bolt axles on hand. In the end, I'm trying to turn a roller into a potential driver with a now missing transmission.
    Jul 2015
    Ohio
    PM sent. I have a couple of trannys to choose from. Fresh with 7:31 R&P and new internals.
    Jun 2016
    Texas, USA
    Thanks for all the offers of rebuilt units or basket cases. I'm looking for a trans for limited use as-is, on a smaller budget.
    Not many 45 year old transmissions that don't need work. No more quick fixes, most need comprehensive overhauls.
