Results 1 to 2 of 2
Thread: 2.4T cylinder heads matched with S cams
    Junior Member
    Aug 2017
    Hi,
    Please can anyone tell me whether I can use S cams with the stock 2.4T cylinder heads in my 2.4T and if so what if any modifications will need to be made to them. Thanks,
    Rob.
    Make the ports the same size as the 'S' ports, set valve springs to same seat pressure as 'S', clay check your valve to piston clearance on those 'T' pistons, and make the induction comparable to an 'S'
