Results 1 to 10 of 15
Thread: permanent operating noise of new fuel pump => is this normal?
    Smile permanent operating noise of new fuel pump => is this normal?
    I just finished installing a new fuel pump. Engine is running and the pump is working
    Question: The pump (FACET, typ FEP87SV) is working constantly (my pre-installed HARDI pump stopped when the pressure was reached and restarted when the pressure was below a certain value).
    This permanent operating noise of the pump is new for me => is it normal for FACET pumps?
    Stefan
    xxxxxxxxxxxxxxxx911 US-delivery 130PS MJ68
    The pump should be mounted on rubber isolaters, then it won't be so noisy.
    this is what I did. So the permanent operating is normal?
    Stefan
    Senior Member 2.5MFI's Avatar
    Sep 2006
    Bend, Oregon
    Yes the FACET pump will run constantly with the ignition on.
    Mark Jung
    MFI Werks
    Early 911S Registry #972
    Carrera T w/LWB, MT, RWS, PCCB
    72 T 66 x 100 MFI Twin Plug Coupe
    R Gruppe #686
    Quote Originally Posted by 2.5MFI View Post
    thanks for clarification!
    Stefan
    Ignition on
    thump thump thump thump thump thump thump thump
    etc.
    and maybe get rid of that Bosch blue coil or your motor will cut out at high RPM and be extremely sensitive to dwell settings.. If you do replace it you will need to put back the ballast resistor (missing- ceramic bar on 68, metal box on 64-67)
    while we are on this photo, that looks like a very early throttle crossbar (from a '66) can you show more?
    What are those vacuum ports in the manifolds?
    Nice looking SWB!
    Nov 2003
    Santa Monica CA
    ports could be for a Sporto? Chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    here we are:
    Date stamp on the manifold is "67" (would match to the delivery date 3/68 of my car)
    Other side:
    The vacuum ports are for the smog pump
    (see thread: http://www.early911sregistry.org/for...ystem-on-my-68 )
    do you mean this one:
    This is my current installation (with rubber isolaters on the backside). I did some test driving with up to 5.000 RPM and every thing was fine!
    Stefan
    New to posting here, sorry.
    But there should be rubber isolators between the pump bracket and the board itself. Mounted behind the board they won't do much to dampen the pump's noise/vibration.
    I should add that the board has its own isolators between the board and the body.
    Jul 2006
    Switzerland
    Quote Originally Posted by 304093 View Post
    Welcome ,.....
    Registry member No.773
