Thread: Hood foam details / removal?
    Almost done with the metal work on my 73.5 targa.
    Last bit is repairing a few holes in the nose of the hood.
    Has anyone found a good way to remove the foam inside the cavity? I need to rust proof the area after welding and this stuff is in the way.
    John Helgesen, ESR member #2003
    Stahlwerks.com
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    acid dip
    or open the cavity
    or minimal-invasive by fragmenting the foam with a sharp tool you insert through the holes but this usually ends with beeing frustrated....
    Would acetone melt it down?
    May 2013
    AUSTRIA (tu felix)
    nope......
