Results 1 to 7 of 7
Thread: Looking for help installing a Talbot 333 mirror. Advice needed!
    Senior Member Fubawu's Avatar
    May 2013
    Hoping someone will have some insight on installing this type of mirror. I want to install it
    in the standard drivers side location but I'm confused by the bottom "bar" type installation.
    I read the instructions and seem a little lost on this one. Anyone have experience with this
    or see it different then I do? Looking at the instructions below it is part # 2 that causes confusion.
Size:  107.0 KBName:  talbot.JPG
    911 1967S 308470
    [B]911 1965 302962 Polo Red
    911 1965 300760 White SOLD
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    Those are designed for mid fender mount
    May 2013
    I'm pretty sure I have seen these in the std door position.
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    Oct 2009
    Indiana
    I have a similar version of the Talbot mirror. It fit onto my door with the factory holes, and the instructions (#2) also confirm that it will work on the door. If it makes you feel better, Talbot mirrors are not terribly simple to install. (It would seem that someone could design a mirror that did not require complete dis-assembly to mount the bloody thing.)
    It's not exactly clear what your question is, except that it relates to the hook (#2 in the drawing). Instruction #4 tries to explain the interaction of the parts, but I think the essence of it is that the J-hook goes inside the door, under the door skin, and then you tighten bolt 3 into #2 to hold it in place. Then you basically have to re-build the part of the mirror that actually shows.
    If I have misunderstood your question, please forgive me.
    May 2013
    Thanks, I think you hit the nail on the head. I'm going to
    give it another go.
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    Feb 2012
    Sweden
    How about a couple of pics while you install it? Pretty sure you won't be the last scratching their head at this
    -70 911E
    -84 3,2 Sold
    May 2013
    I will take a couple pictures when I have it apart. I just tapped the rod to increase the length ...in the pics it will make sense.
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
