Results 1 to 7 of 7
Thread: Right rear light support panel replacement
    Senior Member sebastianroher's Avatar
    Jan 2015
    Florida
    I've purchased the part from Restoration-Design (http://www.restoration-design.com/store/product/PP288R) and I would like to know if there is any recommendations for installing this part. My car was hit at some point in its history and I'm trying to fix the damage that has been done by the accident and by previous "repairs." Some pictures would be nice, I'll post some up of what I'm working on. Thanks!
    Seb
    1971 911t coupe
    2002 Camaro z/28
    Jan 2015
    Florida
Size:  68.1 KBName:  20170826_082046.jpg
    1971 911t coupe
    2002 Camaro z/28
    I'd be inclined to initially screw parts into place then set everything up - deck lid, rear bumpers, and center panel then weld things. A picture if its any help. sorry the car is wrong way up.
    Membership #3255
    301022
    revivem.co.nz
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    there is different positions for the hole of tail light drain tube so make sure you have this right ...
    For sure give your complete taillight housing with the lens you intend to use to your body man. These often times need to be individually fitted. The light housings deform over the years and you'll want to make sure of a custom fit.
    1969 911 E #824
    Jan 2015
    Florida
    Ivan,
    I think your car is a 68 or earlier? Your tail light housing is a little different than mine. Mine looks more like Moito's. Thanks
    1971 911t coupe
    2002 Camaro z/28
    Correct SWB. Sorry at first glance I thought the guts of yours had been cut out althogh same goes for lining the entire rear end up before welding
    Membership #3255
    301022
    revivem.co.nz
