Results 1 to 9 of 9
Thread: Low Idle after repair of alternator
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Had to send out a 45 years all original alternator to been overhaul.
    The service included new diodes, windings, regulator and cleaning of the fan.
    The alternator/fan looks and works very well.
    Unfortunately idle is very low now. Is 600/min, was 950/min before.
    What may be the reason?
    Apr 2011
    N.Calif., south of SF
    Curious- what year and model?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Apr 2016
    Stuttgart, Germany
    72 Ölklappe with 76 2,7s engine and SEV Marchal 70A alternator
    Banned
    Nov 2004
    Scottsdale, AZ
    Warm up then remove the belt. If idle RPM goes up to 950 I'd talk to the alt rebuilder.
    If no change in idle RPM then merely a coincidence? Confirm that your timing and mixture are ok and adjust your idle screw if necessary.
    Apr 2011
    Should you stop the engine first?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Unless you want to lose some fingers.
    Apr 2011
    Trying to get Frank going ....
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Banned
    Nov 2004
    Scottsdale, AZ
    Frank, I would pay for you to demonstrate that technique on PORSCHE 6 while the engine is in the car!
