Thread: 911R hinge placement
    Aug 2010
    Colorado
    I've been trying to locate the proper placement of the 911R hinges. How far from the middle or sides? I did a search and came up empty.
    Chris
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    R hinge placement
    Chris,
    This photo of R5 (T de F winner) shows the rear end view. This car also has the 2 bars which hold the rear window in place, the window is also glued in, and not all R's have the bars. If you use the small top roof vents as a guide for placement, you can just about guess the hinge location. Remember the top edge of the lid is on a curve, so when the lid is open, it makes the hinge want to twist. find a way and attach the lid and hinge without any holes first, and check the twist from closed to full open... If your hinge is close to the real R part in size, it should be in the same area as the photo. hope this is of some help...
    Ernie W
    member of Early 911S Registry
    Aug 2010
    Colorado
    Ernie,
    Thanks for taking the time to post the photo.
    Chris
    www.reSeeWorks.com
    We supply this data with the hinges we make.
    Aug 2010
    Colorado
    Chris,
    Thank you.
    www.reSeeWorks.com
