I have a 1970 911S. I decided to rebuild the shift rod coupler. I started with purchasing the Weltmeister coupler bushings, but they were just a little to big to fit. So I thought I would go ahead and just purchase the entire coupling instead.
The new coupling indicated it was from the OEM provider although did not indicate Porsche. When the new coupling came it fit on the transmission side as it should but the knurled rod is too big to go in the shift rod end. The diameter of my original is approximately 14.98mm while the replacement is approximately 16.33mm. I have owned the car since 1981 and I am sure mine is the original. Anyone have any suggestions or recommendations of where I can get a replacement? Thanks for any help!
