Thread: 73 flag mirror template
    Hello,
    since I'm replacing all the body panels by carbon/kevlar,
    I'll be needing a template to locate the holes on the drivers door
    for the flag mirror.
    can anyone help me with this?
    Thanks in advance!
    Kind Regards,
    Johan
    When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
    What's the difference between heroin addiction & P-Car projects? Heroin use has it's limits.
    Anybody?
    Have to go to the body shop next week..
    Dec 2015
    Bordeaux, France
    Hi, I have my doors off for prepping and I can take measurements and pictures for you tomorrow. It's a 72, is that ok for you? I'm assuming you want the location and size of the holes to drill?
    Best,
    Dario
    ____o0o____
    1972 Targa 911S (one day), silver gray (maybe), member 3337
    Indeed that's right!
    Thanks!
    Dec 2015
    Bordeaux, France
    pictures of holes for mirror
    Hi, I did not have much time, but here are a couple of pictures that I hope will be helpful. The holes are 5mm in diameter and spaced 40mm appart.
    Good luck at the body shop,
    Dario
    ____o0o____
    Thanks Dario!
    Kind Regards,
    Johan
