Thread: SWB with sunroof drain through engine compartment
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    i recently had a look at a 65 911 with sunroof.vin was 301below500
    after i noticed that it does not have the drain slots i had a look at the engine compartment to see if it has the drains exiting at the rear window corners.
    quite surprisingly it dwas not the case.
    i was quite astonished seeing the drain tubes run through the engine compartment and exit through the rear crossmember/slam panel
    the car was /still is used as a rally car and heavily abused
    i had not much time to investigate further to see if the car left the factory with the sunroof .
    lots of bondo etc that made it hard to tell
    but the sunroof looked like a factory sunroof at least when closed(could not open it)
    anyone seen this before?
    Senior Member 9er's Avatar
    Apr 2010
    Adelaide Australia
    I have seen a few variations on early cars, and also early roofs with front drains also.
    Perhaps it is Golde fitted and not factory?
    http://www.early911sregistry.org/for...7&d=1496806276
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by 9er View Post
    Chris
    as mentioned above i had not much time to spend with the car.
    but it is just 5 min away from my place.will take more pics next time i go there...
    was this through engine compartment solution one of the variations you saw?
    thanks for the link
    franz
    Apr 2010
    Adelaide Australia
    Franz, I looked for images today but could not find what I wanted.
    Your picture is the only one that I have seen with hard lines nicely routed to the body.
    This is a good thread, http://www.early911sregistry.org/for...Sun-Roof-Coupe
    May 2013
    AUSTRIA (tu felix)
    thanks for the lead,Chris
    will move to there...
